Fit Spline Extra Line
I am having trouble using the fit spline function. I start with two perpendicular lines in a sketch and create a sketch fillet on the corner. When I use fit spline on those three elements (disabling "close spline" and lowering the tolerance to 0.0001), a chord appears between the two endpoints of the fillet. This gives my sketch contour issues when I try to extrude a surface. I've seen tutorial videos of this where the chord doesn't appear, so I must be doing something incorrectly. Any help would be much appreciated.
Thanks!
Thanks!
RE: Fit Spline Extra Line
Also what is your SW version and SP.
Deepak Gupta
SW 2010 SP4.0 & 2011 SP1.0
DriveWorks Pro 7 SP5
Boxer's SolidWorks™ Blog
Is the chord an integral part of the spline?
When I get home, I will take a screenshot to explain my problem. Thanks again.
btw, I am using Solidworks 2010 with SP 0.0. How do I obtain updated service packs?
Thanks for the help.
Cheers,
Anna Wood
Core i7 EE965, Nvidia Quadro 5000, 12 Gb RAM, OCZ Vertex 120 Gb SSD, Dell 3008WFP 30" Monitor
SW2011 SP0, Windows 7 x64
http://www.solidmuse.com
http://www.phxswug.com
Also can you try a complete reinstall of SW.
Deepak Gupta
Anna Wood
