Manifold outlet spacing
Ive read the threads where people have been talking about pressure loss across manifolds and ive got "Perry,s chemical engineers handbook" for all the formulas. In learning how to do the pressure loss calcs ive got the impression that the spacing of the outlets from a manifold effects the pressure loss. Perrys talks about distances between fittings effecting pressure loss and gives formulas for calculating it but dosn't do so for outlet spacing.
How do I do this or do I just need to ensure that the spacing is even? I am pretty sure that it is something to do with ratio of outlet diameter to manifold diameter but thats all ive got.
RE: Manifold outlet spacing
You can find a valid example of manifold (header) sizing at
Pag. 226-228 "Flow in a manifold" (example 7.3) Chapter 7 from "Chemical engineering Fluid Mechanics, second edition revised and expanded" by Ron Darby.
So to minimise the pressure drop you can increase the manifold diameter and make the outlets very close together.
My fear is that it is not that simple. If it is then that is great but I think that the outlets have to have a certain seperation or the currents in the manifold into the outlets interact and cause a higher pressure drop.
However if it just tells me how to size the diameter of my manifold to ensure even distribution of flow then it won't help me because I already know how to do that. My concern is that the spacing of the outlets effects the pressure loss. For example if the friction loss for two 90 degree bends separated by a distance where r/d=0.5 (radius of turn dived by diameter of pipe) is four times that of two bends seperated by a distance where r/d=1 then it would follow that while you may reduce pressure loss due to the length of the manifold pipe in a manifold by making it as short as possible you could increase the pressure loss by having the outlets too close together.
So if I have a very large pipe so that the loss along it s length is negligible for the required flow then what people seem to be saying is that the pressure loss between a design where I have my outlets as close together as is physically possible compared to one where the outlets are 5, 10 or more diameters apart is negligible, ie equal to the loss in the very large pipe.
That dosnt seem right to me. When water is entering an entrance water comes from straight in front, sides and all around. If outlets are close enough together are they not going to compete for water making the way that the water moves in the large pipe different to the way it would move if the outlets were further apart?
I know guys have said not to worry about it but I not only need to get this right but, I need to be confidant that it's right and I need to know why it's right.
Ive been told by my flow meter supplier that in order for them to work accurately I need 10 diameters of straight pipe before and 5 diameters after in order for there to be a stable velocity profile. This got me thinking that if I have the inlet to my manifold at one point and the outlets scattered to the left and right unevenly then it would be likely that the turblence of the water entering the manifold would effect the flow into the outlets.
People have said not to worry about this but it just doesn't seem right.
M=manifolds 225mm
I=inlet 100mm
O=outlet 65mm
I
I
O O I O
O O I O
MMMMMMMMMMM
O O O
O O O
Hope that is clear.
