grounding
grounding
Hello All,
We have a new system that is fed from a single D-Y transformer. We are now adding an alternate source (a generator). We would like to resitance ground both sources.
The questions is can this be done with one NGR? The suggestion was made to place a zigzag with NGR in the secondary lineup so that we only need one NGR for both sources....does a zigzag work fine on a the secondary of a wye transformer?
RE: grounding
Rafiq Bulsara
http://www.srengineersct.com
RE: grounding
RE: grounding
The zig-zag is the joker. It is used one of several methods used to generate or develop a neutral point for grounding when one does not exist. Artificial neutrals are superfluous when a true neutral such as a wye point exists.
This brings us back to Rafiq's suggestion, hire someone who knows grounding.
As for a single NGR, not enough information to say. It depends.
Bill
"Why not the best?"
Jimmy Carter
RE: grounding
Commercial Applications
RE: grounding
What is the KVA rating of the generator?
Is the generator wye or delta?
Bill
"Why not the best?"
Jimmy Carter
RE: grounding
RE: grounding
http://www.postglover.com/pulserplusnet.html
