Laser diode sources (Where to buy)
Does anyone know of a source to buy laser diodes? I am interested in the red 650 nm used in laser pointers. The ones I find are usually expensive, while a laser pointer costs about 4 dollars, but I can not find the diodes at this price or less. Also, I am looking for green laser diodes that I can purchase for less than the price of a green laser pointer.
RE: Laser diode sources (Where to buy)
Not only do you get the laser modual, but you also get the lens, the driver circuit, the adjustment spring and housing. You can't beat that for the price, really.
How many laser diodes do you need? Only a very high bulk price will enable you to purchase such diodes at the kind of price you are looking for.
As far as green goes, well, they are not just a laser diode. They use an infrared laser diode, at 808nm to pump a small crystal of vanadate to get an output of 1064nm, which is then frequency doubled through a non-linear optical process to 532nm. It is a DPSS laser, or diode pumped solid state laser. It is better to just buy the pens, for the money. As far as I am aware, they do not yet sell green laser diodes.
Hope this helps.
Thanks again,
Steve
