gINT Log design
gINT Log design
I have a question in regard borehole log design. Can I have the left orright, or both lines of a column stop any indicated place below the topline of the header? I want to draw a horizontal line for several columnsand give a common name of SAMPLE for instance above this drawn line, andalso have their own head names below this line. In order to achievethis, I need the vertical column lines to stop at this designed lineinstead of reaching the top.
I found the manual of the gINT is too bad and be made this way purposely.
RE: gINT Log design
I haven't understood what you would like to do. Can you rephrase or attach a diagram?
RE: gINT Log design
Ok. I have another question. I have a column of Hydraulic Conductivity. The range will be from 0.01(-2) to 0.0000001 (-7). I want to have the header scale at 10(-3), 10(-4), 10(-5) and 10(-6). How can I do this.
I have made it this way. Set the range from -7 to -2. Have the number in the header with the color WHITE. Write the number 10(-3), 10(-4), 10(-5) and 10(-6)to the places instead. Obviously, this is not perfect. Do you have a better way? Thank
