Deflection of a dome from a point load
Has anyone seen a formula for calculating the center deflection of a dome, if you know the dome thickness and material, from a point load towards the dome from the convex side at the center of the dome?
RE: Deflection of a dome from a point load
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
TTFN
Chinese prisoner wins Nobel Peace Prize
An axi-symmetric analysis in a FEA program would give you the answer for a point load at the crown.
For a point load anywhere else you would need to do a full 3D analysis.
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
TTFN
In Roark?
Which Edition?
Mine (Edition 7, 2002) only goes up to Table 17.
Doug Jenkins
TTFN
Found it.
Table 13.3 - 3b Page 611 in Edition 7 (International Edition)
Doug Jenkins
If you're going to be doing stuff like this as a professiona, a copy of Roark's Formulas for Stress and strain is a good addition to your personal collection. Just remember that Roark is not the author (since the 5th ed) - you won't find the book by looking for him as an author.
jt
TTFN
Unless the dome is very shallow the best table to use would be Case 2 from Table 13 (Seventh Edition), rather than Case 3. The description is "Partial spherical shell, load P concentrated on small circular area of radius r0 at pole; any edge support".
Doug Jenkins
AddALL
Bookfinder
BestBookBuys
AbeBooks
TTFN
Incidentally the deflection of almost any structure to a point load is infinite.
Cheers
Greg Locock
Surely undefined, rather than infinite?
In "practice" on Earth the deflection of the structure would be zero, and the deflection of the load would be about 6400 km :)
Doug Jenkins
While Walter/Bullfinch/Meigs et al may have had arguably primitive design knowledge (and built as you will see with cast iron arches), I think these arches have basically supported the dome and superstructure vs all/whatever loads applied since ~1866. [It appears according to ht
Everyone have a very Merry Christmas.
