ATI and I-DEAS
ATI and I-DEAS
ATI and I-DEAS
Does anyone knows if I-DEAS NX11 or another version works with ATI Mobility Radeon™ HD 5650.
And under windows 7 or xp?
Thanks to all
RE: ATI and I-DEAS
Most CAD systems will work with the Radeon series of cards, just they aren't certified. If you have graphics problems, you are on your own.
The difference between the gaming and engineering cards is where the intense OpenGL processing is being performed. Most gaming cards are designed for Direct-X display generation. Engineering cards are designed for OpenGL display processing. Using a Direct-X card for a system that is outputing OpenGL calls, requires the CPU to perform the display calculations and pass them to the card for display. This slows down the CPU. With an OpenGL card, the raw commands go to the card and its GPU does the display generation.
Ben Loosli
RE: ATI and I-DEAS
You should be able to go GTAC Web site to see if this card is supported.
I Do not think I-Deas NX11 is supported under Windows 7
Once again check the GTAC website
You will need to create a web key account
http://support.ugs.com/gtac.shtml
