assembly features
assembly features
I have made some changes in a top level assembly to a part. Is there a way for me to make those changes revert back to the part file? Or can I only see those features in the assembly?
RE: assembly features
More details are needed.
-Dustin
Professional Engineer
Pretty good with SolidWorks
Deepak Gupta
SW 2009 SP4.1 & 2007 SP5.0
MathCAD 14.0
Boxer's Blog
Dan
www.eltronresearch.com
Dan's Blog
After reading your comments and trying out your suggestions,
what I am finding is that I can propagate the cut-extrude back to the part file but the curve driven pattern does not have a feature scope section, however it is easy enough to recreate the curve driven pattern in the part in this case. In the case that I had a more complex pattern is there a way to propagate a pattern back to the part?
When in the assy, select the part and click the Edit Part icon, then create whatever features are required.
