Fin Fan Cooler - Condensate Leaking from tube header
Hallo,
I need simple help, I ahve problem with leaking of liquid from tube header. Beside replacing the new plug ( if the internal threaded still ok) or welded the plug ( last option and will provide no more option for instrusive inspection), is there any new techniques or applications (such as technical approved sealant)which can use to overcome this problem.Thanks
RE: Fin Fan Cooler - Condensate Leaking from tube header
Try "Old School" first.  Try tightening up the 'leaker'.
If that doesn't work: Take offline and drain header down below plug.  Pull leaker, chase the hole threads lightly if they look good, recut a round or 2 if threads look 'wasted'.  Then install a new plug, using a good grade of pipe dope, like "RectorSeal Soft".
Duwe6, tqvm for the info....really appreciate it.
I would use welding as the last resort as the heat input may affect the adjacent plugs - you might fix the leaking one but have the ones surrounding it leaking too.
Adam Potter MEng CEng MIMechE
www.ax-ea.co.uk
