Thermal Simulation doesn't finish
I am attempting to model heat transfer from a set of pipes with a surface temp of 1100F to a tank with temp 80F.
I have set the initial temps of each part to the above temps.
I have also set up radiation and convection on the 1100F surface.
I am using the Direct Sparse Solver, however it is stuck on a loop.
The total completion bar will reach 99.9/100% and then reset to about 98%.
The tasks occurring are Decomposition of conduction matrix, and establishing a stiffness matrix.
Its been 1.5hrs and I'm not sure whats going on
RE: Thermal Simulation doesn't finish
