Use of graphite as a microwave energy absorber for heat transfer
I'm investigating building a melting cupola that is radiated by 2450MHz microwave to aproximately 2600F. I plan on using graphite for the cupola and I'm wondering what kind of absorption to reflection ratio I should expect to see and how will the graphite hold up to delivering energy to it in this manner. The radiation will be striking the surface at varying angles because the cupola tube is round and placed on the cental axis of a triangular chamber with the microvave radiation reflecting off of the triangular walls.
RE: Use of graphite as a microwave energy absorber for heat transfer
In short, you need some detailed analysis of the problem. Suggest you hire a consultant.
www.MaguffinMicrowave.com
Maguffin Microwave wireless design consulting
