Word to PDF. Removing Pop-up of 'Save PDF file as'
I am trying to convert word to PDF using Acrobat / PDFMAker using VB.
I could get it to successfully convert word to PDF i.e. running PDF Maker ,but it pops up a dialog box" save pdf file as" . I want to remove that pop up box and pass a variable of file name etc.
Could you giude me on that?
thanks
Girish
thanks
Girish
RE: Word to PDF. Removing Pop-up of 'Save PDF file as'
C:\WINNT\SYSTEM32\SPOOL\DRIVERS\W32X86\2
and you won't have any more the popup.
If you do some good stuff, please inform me.
Tkx
FT
I thought that there was a setting somewhere in the registry for that (PDFfileName or FileNameSet...) I will keep on digging.
Thank you,
Chuck Foss
Still in process...
http://www.wotsit.org/search.asp
and do a search for pdf. It will point you to a 3 meg download of the filespec.
Good luck in you efforts to re-invent the wheel!
Hint - There are several freebie convertors out there already - Google will find them for you
Good Luck
johnwm
Use this code at the end of your procedure.
