Plastic Lined Steel pipe issues.
I would like to know how to install plastic lined steel pipe in a typical process.
Is it true that Lined pipes must be purchased premanufactured by specifying precisely the lenght of each unit, beacause it is impossible to cut the pipe the right lenght on site (Can Affect the plastic internal coating in the cutted section.)
If it's true, it would be really a problem for me since it's quiet difficult in my project to have exact lenghts (no precise Isometric pipe drawings available). I guess in this case we have to have very precise isometric drawings. Is there any other way?
Do you think that, like conventionnal steel pipes, plastic lined steel pipes lenghts can be ajusted on site to match each installation case?
Thank you very much.
Djaz.
Djaz.
RE: Plastic Lined Steel pipe issues.
A pain in the butt dimensionally however. Can't really see a good way around that.
http://www.insituform.com/
http://www.naplinc.com/
If you have enough money to spend, you can buy a bunch of assorted length spools, assuming they are allowed on your project. And if your length variation increments aren't too small.
1. Design into your pipe "spacers" at strategic points, say 1/2" thick, that can be machined to whatever thickness you need to make up for gaps. Spacers can be made out of polypropylene.
2.Resistoflex provides a "Field kit" with dies and mandrels where you can cut the pipe to length (leaving a length of liner extending past the face), thread the flange onto the pipe, and then heat the end to flare the liner onto the flange face.
A long time ago, when Dow made lined pipe and fittings, pipe spools were field made up by cutting the liner flush with the end of the pipe, thread on the flange so that the face of the flange was flush with the face of the liner and pipe, and then machine a small groove into the end of the pipe and flange face. A gasket, which looked like an over-sized o-ring, would be installed to mate up to a lined fitting or another spool.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
I would like to thank you all for these valuable information.
I am studying all these possibilities (Using Spacers, pull a liner through the pipe, Resistoflex Field kit, etc.) to understand the pros and cons for each solution.
After that, I think that I will probably have more questions about these solutions.
Please feel free to add any suggestion.
Thanks again and sorry for cross-posting!
Djaz.
