2002 Mercedes Benz C320 Alternator
I am doing some engineering research and here is my question: Anyone knows the brand and amps rating of the 2002 C320's alternator? What is the pulley ratio between the alternator and the crankshaft pulley? Same question applied to this cars: 2002 Volvo S80 2.9L and 2002 Hyundai Sonata V6. Your help would be much appreciated...
RE: 2002 Mercedes Benz C320 Alternator
http://img.eautopartscatalog.com/live/F400068250BOS.JPG
If so its a Bosch.
Once you know the alternator manufacturer and the part number you can usually find all the other information you need at an aftermarket automotive parts supply vendor that handles Bosch or whatever the OEM manufacturer is. Bosch has a good online network if you do a search for it.
Chumley
