Geometrical Set Question
hi everyone
Let me please tell you that I'm working with Geneartive shape surface module I received one CAD model in igs file format then I break up the model in parts using geometrical set
inside of each geometrical set I tried to remove gaps surfaces whit healing surface and finally I did a join surface
what I'm looking for is to have a whole closed surface but when I try to link the geometrical set between each other the model became in a mess
mi question is how should I work in catia with many geometrical set to assembly the whole model to have one model closed? how should I work with many geometrical set to have control of what I doing?
thank you all and hope please to have news from you
see you in advance
Enzo
see you in advance
Enzo
RE: Geometrical Set Question
Personally, after grouping the surfaces into sets for each part, I would add a second Geometric Set for each part for any new features you add to the IGES data (healing, joins, new curves, etc.)
- GEOM SET PART A (FROM IGES)
- SURF.1
- SURF.2
- SURF.3
- GEOM SET PART A (MODIFIED)
- SURF.20
- JOIN.3
(same two Geom Sets for each part)
- PART BODY
- CLOSED SURF.1 (PARTA)
- CLOSED SURF.2 (PARTB)
I will try to do what you adviced me I think is good answer thank you again
Kind regards
all the best
Enzo
