Help in VB NX7.5 for pattern more than 500 emboss
Hi
have a look at pattern.prt
I want to duplicate emboss(7).
I use CTRL-C then CTRL-V
with link to original and reuse original
then I select arc(4)
OK
CTRL-V
then I select arc(5)
OK
until arc(504)
It works but It's time consumming !!!!!
So I created the journal file to past the previously copied emboss(7) on arc(4).
I was able to edit the journal file pattern.vb to change arc(4) to arc(5) for example and it works
Does anybody can help to create a sample loop in my journal file to duplicate the emboss(7) from arc(3) to arc(506) ?
Thanks in advance
OK
CTRL-V
OK
until arc(504)
Thanks in advance
Didier Psaltopoulos
http://www.psi-cad.com
