HEC-RAS - Joining multiple files
Looking for a process to join several HEC-RAS files together for a system wide evaluation. Some way to take stream reach cross-sections and combine with other reaches without doing manual input. Can anyone help?
RE: HEC-RAS - Joining multiple files
When you're in the geometric data, select file, import geometry data and follow the steps from there. A bit relatively straight forward work would be required to get the model up and running properly.
