Eyebolt proper analysis
I have been asked to perform an analysis on this particular eyebolt. I want to find out the force it takes to yield the eye at the critical points. I am not worried about the bolt pulling out of the concrete because the bolt length (under the eye is 24") and is been tested (in pure tension) to handle over 30 tons of tension force.
When the eyebolt is loaded in pure shear (as in the diagram) it will create the most stress under the 2" base in the discontinuity (where the 1.125" rod meets the 2" shoulder). I have done prelimary calcs resulting in a yielding force of around F=25000 lbs (by resolving the horizontal force into an equivalent moment and shear located just under the shoulder.
I am interested in a method to analyze the stresses in the eye part (0.9")?
RE: Eyebolt proper analysis
Ted
http://www.codipro.net/xml/index.html
