solenoid failure
solenoid failure
Im wondering if anyone has any experience with or knowledge about solenoids activating involuntarily. For instance, if a solenoid was used to close the circuit to activate a pump, is there any way (due to extreme conditions like submerged in salt water, physical damage etc.) that the solenoid could cause the pump to engage without the armature moving due to a magnetic field.
Thanks in advance,
Earl
Thanks in advance,
Earl
RE: solenoid failure
thanks again
David Castor
www.cvoes.com
