Vinyl Chloride to Ammonia
Does anyone have a good technical reference or insight on changing a vessel's commodity? I have a old rail car that stored vinyl chloride that I want to use to contain ammonia, and wanted to know if there are any concerns in doing so.
Thanks!
RE: Vinyl Chloride to Ammonia
Anhydrous ammonia is no particular problem in carbon steel; pipeline, tankcars, etc. Except, be sure the anhydrous ammonia contains a trace of water; I think 0.1 % gives a safety factor. Pure anhydrous can stress corrosion crack higher strength "carbon" steels like T 1.  I believe many years ago, process units were adjusted to leave a trace of water in the anhydrous.
Thanks Blacksmith 37 for the response!! Is there any problem switching the tank from vinyl chloride to the ammonia?  Was thinking more along the lines of residual chloride in the tank and then being introduced ammonia....any thoughts?
Have not been able to find good technical references regarding common commodities meeting each other when tank substances are changed.  Is there a standard cleaning method used before changing out commodity?
Switching between ammonia and LPG was not a problem ; no experience with vinyl chloride.
T1 is  ASTM A514, 517 type material.
Was the railcar given PostWeld Heat Treatment?  PWHT is a requirement for liquid Ammonia service [due to stress-corrosion cracking].  And, due to an OSHA clause, it is also a legal requirement in USA.
Duwe6, thanks for the response!  Do you know the OSHA clause that requires it?  I assume ASME would have required it because Ammonia could be classified as a lethal service, hence requiring PWHT?
1910.111(b)(2)(iii)(a)
"Containers shall be stress relieved after fabrication in accordance with the Code."
Poorly written clause.  Their intent is that all welds receive PWHT 'for process', including small nozzles.  This differs from the ASME VIII requirement of PWHT based on thickness and/or materials of construction.
Go to OSHA.gov and read the whole of 1910.111, including the Intrepretation letters.  Among other 'perversions' of the B31.3 Code, OSHA does not allow threads on Sch40 pipe [welds only -- prudent], but refuses to allow backwelding of threads on anything thinner than Sch80 [not a B31.3 requirement, just a ridiculously stringent requirement thought up by OSHA burocrats].  Thus all installed threaded Sch40 is required by law to be removed.  You need to be well-informed about the OSHA requirements before you start your project.
