Alters message
Alters message
Alters message
When i click on command like 'SUBTRACT' Part Nagivator tree. I will display the 'Alters' message what is reason....... and to avoid this....... Please find the attached below...
Lokesh
RE: Alters message
If you wish to edit the subtract, try 'edit with rollback'.
This particular alert you can ignore. It is telling you the tool body is missing, but in the subtract options you told it to remove it, making the alert redundant.
RE: Alters message
thanks Cowski
