Laterally connecting two parallel beams
my problem is to connect two beams in my model like they were welded together on their side surface. Then one of the beams (the upper one on the picture) is put on strain with a concentrated force. This would cause the other beam not only to bend but also to twist due to the moment caused by the loaded beam.
I tryed to implement a COUPLING constraint, by adding a partition edge on each beam and connecting them, but this did not work as the was no torsion recognizeable.
Connector sections also seem to be inapplicable, as they can only refer to the vertices on my model (can that be changed?). I would be very happy, if anyone can help me...
RE: Laterally connecting two parallel beams
Tata
Tata
