compression tester
compression tester
Hi
I have been locking for a compression tester for diesel engine on ebay
The ones marked for diesel seam to go for big money
But the one that say petrol, start at a tenner
h ttp://cgi. ebay.co.uk /PETROL-EN GINE-AUTOM OTIVE-COMP RESSION-VA LVE-TESTER -TOOL-/110 612040566? pt=UK_Hand _Tools_Equ ipment& ;hash=item 19c0fdcb76
http: //cgi.ebay .co.uk/AUT OMOTIVE-CO MPRESSION- TESTER-KIT -PETROL-GA UGE-VALVE- /150532804 103?pt=UK_ Diagnostic _Tools_Equ ipment& ;hash=item 230c744e07
I seams that you thread the test into where the spark plug threads
there are several kinds of threads for spark plugs and my question is; is there a way of getting these compression tester to fit and seal into where the injector goes into a diesel engine
James
h
http:
James
RE: compression tester
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
First the pressures are higher than those found in a spark ignited engine, some diesel engines I'm familar with have a cranking compression pressure of nearly 400 PSI.
Next, gas engines use spark plugs, usually 14 or 18 mm threads, so a couple of adaptors will allow a pretty broad use of the test tool. For diesel engines you typically need to remove an injector or nozzle, and the test adaptor needs to be the same size/shape as the removed component. No standard for most engines, every manufacturer has their own injector, hard to find a one size fits all tool for that.
You can likely make an adaptor from an old injector if you carefully gut it and have a good fabricator make up your adaptor for the check valve and gauge. But make sure it fits well and is well made, as you could up end with an unwanted addition to your forehead, as pointed out above.
Hope that helps, Mike L.
The glow plugs on a VW TDI are M10x1.0 which are the same as most modern motorcycle engines use for their spark plugs, so that's the adapter you use.
And don't forget to find a way to disable fuel supply prior to cranking the engine to check the compression ...
This could be done I suppose, taking the inners of the injector out and cutting a thread inside it
But I need a pressure gage of up to 400 psi right not 300
So what I need to do now is find a pneumatic gage of 400 psi
And find a thread cutter with the same thread on as the end of the gage
James
As to the pressure...What's the problem with only 400psi? Right tool for the job too expensive? I've got IC race engines that are pumping 250 plus and I use a regular gauge that reads to 400.
Rod
[imghttp:
[img]http:
Well as you can see the injectors are out and are somewhat grubby
Just I though if I cleaned them up put them back on would the engine fire much easyer
As dgallup says this is quite a farce
If i threaded a nut onto the fuel inlet of the injector as seen in the photo and threaded a reducing bush inside the nut to thread onto the end of the gage tester or visor versor
That would allow me to put the compression tester stright onto the injector without removing the injector only to remove the compression nut from the injector pump
I cant find my fella gage so I dont know what size thread it is
It looks to course to be pipe thread but if it was I would say 1/4 BSP /NPT
Could be metric course though
Only way to find that out is with micrometers and fela gage??
Rod
For I leak down test dont I need the following
2 x gages
pressure regulator
and an orifice?
Thank
James
ht
I have bough gages from this firm in the past for pressure washer on cleaning plants
The gages worked well
However the gage is for hydraulic and dose not state pneumatic
So how do you think it would work with air as opposed to liquid??
A couple cheap alternatives for the DIYer...It's not Snap On, but it gets the job done at a quarter the price.
ht
http:
http://ww
htt
Rod
