Does UG have a "set working directory" like Pro/E?
Does UG have a "set working directory" similar to what Pro/E does?
Everytime I switch to a different project (which is in a different directory), I'm constantly having to re-navigate the directory structure to get to the correct directory.
And I have to navigate when I do a parasolid import, again when I do a step import, and again when I do a parasolid export, and again when I do a step export.
Is there an easier way?
UGGuy!!!
RE: Does UG have a "set working directory" like Pro/E?
Hi UUGua,
You will gave to change the Customers Default Directories:
File -> Utilities -> Customer Defaults -> Gateway -> Translators
There you can set the In & Output Directories to where you need them.
You "Working Directory" you can set here:
File -> Utilities -> Customer Defaults -> Gateway -> General
Grtz,
Best regards,
Pascal,
NX5.04+TC2007 (GM Toolkit) / NX7.5 native
