Bolt stack rule change in NX 7.5
I'm using the reuse library along with the hole series command in NX7.5 to add ISO bolt stacks (bolt, 2 washers and nut) to an assembly, however, it always seems to offer the default bolt choice as being to long (far too much thread protruding past the nut) Is there anyway of changing this?
many thanks in advance.
Best regards
Simon NX4.0.4.2 MP10 - TCEng 9.1.3.6.c - (NX7.5 native)
www.jcb.com
Life shouldn't be measured by the number of breaths you take, but by the number of times when it's taken away...
RE: Bolt stack rule change in NX 7.5
If you change it in the dialog, Dialog Memory will remember the new setting.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Super job! thanks John.
Best regards
www.jcb.com
