Pro Table help
Pro Table help
A Pro/E model having around 200 instances.
All the dimensions having the parameters with unit in inches. While displaying in drafting table the dimensions should be display the mm value (Model should be in inches). please check the attachment.
Which option I have to use for this conversion?
RE: Pro Table help
Since you want it in a table an other option would be to make an equation that converts it just for the note. So you would have a relation for the note that says something like "mmnote1=ad3*25.4".
There may be better ways to do it, that is just what I can think of off the top of my head.
RE: Pro Table help
Relations that convert the table values is the best way to handle it.
Ben Loosli
RE: Pro Table help
Thanks for all your valuable suggestions.
I used relations with parameters for conversion. In tables Repeat Region and Filter option to filter out inches. Its working fine.
