Eccobond 285 Properties?
I am looking for mechanical properties of Eccobond 285 by Henkel (formerly Emerson & Cuming).  The Technical Data sheet only has density and lap shear strength. I need to have Modulus of Elasticity at least.  Ultimately, I would like to investigate stress relaxation if those properties are also available.
RE: Eccobond 285 Properties?
Several years ago I was told by E&C that the eccobond 285 was "almost identical" to stycast 2850 and I have used E = 1E8 Pa. The 285 has good thermal properties since TCE is 29E-6/C. We do not use it for strenght at hi temp of 95C but it is stable. Us the 23 or 24/lv catalyst for wide temperature range.
Thanks jedward.  At least this fills in one of the "tbd" items from the vendor data sheet.
