Need Copleland compressor curves please
If anyone has access to the Copeland compressor selector software, I would sure appreciate a curve printout.
Not certain what is req'd for input, but here are some numbers.
Compressor ZPS20K4E-PFV-830
Scroll running at 100% capacity
R410A
20 deg TD at condensor (70F in, 90 out)
25 Deg entering evap
12 deg superheat
Much appreciated!!!
R410A
12 deg superheat
Much appreciated!!!
RE: Need Copleland compressor curves please
JCHP, Go here for the spec sheet: http
looking for someone who has access to the Copeland software
to run the charts (cond vs evap temps) based on my conditions.
You have to be registered with Copeland to access the software.
Cheers
