SolidWorks 2010 Hole Wizard
When trying to edit a part that has features done with a hole wizard, an error pops up saying "Out of memory or other error trying to initialize data source from standards file." Then it gives the file path located on the C drive. I tried moving the file onto the main server where the particular part is located, but the error still appears when trying to edit the hole feature. If SolidWorks is completely closed and restarted, the error wont appear for a while.
RE: SolidWorks 2010 Hole Wizard
The Hole Wizard works OK in a new session of SW, but after working on the model for a time the error message appears?
What are your system specs? (CPU, RAM, VM setting, 32 or 64 bit)
Patrick
SolidWorks 2010 SP4
ThinkPad W500
Core 2 duo P8800 2.66 GHz
3 GB Ram
ATI Fire GL V5700
Windows XP SP3 (32bit)
Welcome to my world.....This is an ongoing tech issue with my VAR. Are you on a 32 bit system, and how much memory do you have? I do not see this on my 64bit system at home, so I think it's a 32 bit issue.
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2010 SP 3.1
Dell 490 XP Pro SP 2
Xeon CPU 3.00 GHz 3.00 GB of RAM
nVida Quadro FX 3450 512 MB
3D Connexion-SpaceExplorer
Forgot to add I have to perform the same exact steps as you as far as closing and reopening files. It's a real PITA! Try and keeps other apps open to a minimum.
Mechanical Designer
Mechanical Designer
}:O)
Mechanical Designer
Mechanical Designer
Let us know what you come up with, thanks,
Colin
Mechanical Designer
Any fix on this? Are you still experiencing the problem?
Mechanical Designer
Mechanical Designer
Mechanical Designer
Mechanical Designer
