PWHT applied to used equipment not previously PWHT
Good mornign all, question...we are trying to change the service of existing equipment to a high H2s service which wil require us to PWHT the SA516-70 material. the original data sheet and service did not require PWHT. what should i be preprared for? I understand we will have to be NBIC compliant,
RE: PWHT applied to used equipment not previously PWHT
1) Is it cost-effective to PWHT the entire vessel, or local PWHT every weld? Would it be cheaper to just purchase a new, PWHT'd vessel?
2) If cost-effective, and the Mfr is no longer in business, then write a Non-Conformance Report on your vessel. The disposition will have to be signed by Owner, Vessel Engineer, Quality, and AI. This will be your forum to decide if PWHT after-the-fact is the proper decision. "Alter using PWHT" should be an acceptable decision, assuming that 'normal' weld materials were used.
