Radio propagation(millimetric wavelengths)
Is there any relationship between the K-Rician factor and the coherence bandwidth?
RE: Radio propagation(millimetric wavelengths)
Well that's a good one and not a very short answer I'm afraid.  The Rician K-factor is defined as the ratio of the signal power in a dominant component over the local-mean power.   The coherence bandwidth could be defined as the correlation of fading at different carrier frequencies and is computed as such.  .. So the short answer is yes.. their is a direct relationship between the K-Rician factor and the coherence bandwidth.
