Overall heat transfer coefficient of Therminoil
can some one help me with a typical value for the overall heat transfer coefficient for Therminoil 72 or 66 when used to collect heat from hot flue gas in a steel heat exchanger
RE: Overall heat transfer coefficient of Therminoil
Is this a flue gas ecomomizer with studded tubes?  Any enhancement on the gas side?  What diameter tubes, what wall thickness?
Are we supossed to guess what this thing is?
I am looking for a value that i can use to evaluate the size and the cost of the heat exchanger. I have not reached the level of the detail design yet. all i need at the moment is a typical value so that i can use to evaluate the economics and determine if it is worth going for the project.
IRstuff i have not been successful in getting information from the manufactorer.
if you can not find therminoil specificaly a value form any thermal oil will help
