what qualifications are needed?
in regards to cars (in Australia)
what qualifications are needed to approve of
*engine transplant (with a motor that the vehicle did not come with)
* modify the drivetrain (such as going from fwd to 4wd)
* modify suspension mounting points
i have a mini moke and im looking at changing it from fwd to 4wd, this will also consist of a different engine, and also the need for suspension alterations
and where can i get guidlines of what i can and cant do, and the correct process of doing it?
thanks for any help
thanks for any help
RE: what qualifications are needed?
Every state has different requirements and limitations, and different procedures.
One place you could start your search (that I am familiar with) is a Hot Rod Forum called, Ozrodders.
You will not be able to road register it as a Hot Rod, but that Forum might give you some insight into the very confused world of getting highly modified vehicles road registered.
http://ww
