Calculating particulate entrainment from riprap
I've been using an equation from Izbash(1970) to help predict stable stone sizes for riprap which could undergo river flow rates of up to 10m/s, unfortunately, the resultant Dn sizes seem rediculously large. Is there a better more realistic formula for estimating the size at these high flow rates?
RE: Calculating particulate entrainment from riprap
USACE has a design method you can use to verify your calculations, it is available online.
Publication Number: EM 1110-2-1601
Title: Engineering and Design - Hydraulic Design of Flood Control Channels
http://1
With regards to the calculation, the formula requires larger rock sizes in a linear fashion relative to flowrate. However, as I understand it, the rocks are sized at a nominal diameter and are assumed to be spheres for the convenience of the calc. This does not produce a linear increase in weight relative to the linear requirements for larger diameter rocks, therefore at 10m/s an average rock size of 7m dia is required, weighing in at 511te, which seems a tad heavy to me...I've added a pic. of the bank in question
PS I've calculated a flowrate of 2.7m/s gives a stone Dn of o.4m
