missing midside nodes
I am trying to generate INTER20X elements using CZMESH commands. but i keep getting the error message "no cohesive element was generated between solid elements xxx and xxx (and possibly others) because of missing midside node(s) or other connectivity issues"
i unselected my area mesh element type before issuing the CZMESH command. Maybe that's the reason why but without unselecting the area mesh elements i would not possibly generate any at all because i'm using different element types for area & volume meshing
Thanks everyone. any help will be much appreciated.
Kind regards,
Ee Lian
RE: missing midside nodes
btw, my model is three nested ring cylinders. i'm trying to generate interface elements between those rings, ie two interface layers and three rings.
sorry, i really suck in ANSYS.
thanks in advance. hope that i'm providing enough details in my question :)
problem solved :) Thanks
