Design with Yield or Ultimate stress?
Hello Guys,
i my attempts to get practical experience with FEM, i reverse engineered an excisting part and used actual (fairly accurate) worst case loading.
After refinement the stress in the tooth fillets are considerabel above yield. The stress is actualy around 390MPa for ductile iron, which has a yield of 320MPa.
Basically this would mean the part would yield in the filled in service, but i'm reluctant to accept this, since the actual part has been in service for years without any failure in the fillet with the "too high" stresses.
Simply put, i'm confused how to deal with this..
Now my question: do you guys "accept" parts for prototype testing even if the FEM is above yield (but below ultimate)?
p.s. again, the stress is real and not a hot spot. The high stress is the location one would expect it to be in the actual part. Furthermore i double checked the loading with actual test report data.
RE: Design with Yield or Ultimate stress?
yes it it cyclic.
The stress (P1) in the fillet fluctuates per revolution of the part.
The lowest value of P1 is near zero, so the fluctuation is almost equal to the max. value of P1, the 390MPa.
Tata
Is it common to design for fatigue and not for yield for such critical components?
It seems to me the risks are a lot higher this way(what will happen in service?,loads not underestimated?,subpar material casted?). Furthermore extensive fatigue testing should also be done, which is all but cheap.
Just curious.
Tata
Yield strenght: 320MPa
Bending fatigue limit(non-symmetric): 380MPa
Since the stress cycles from near zero to Max. P1(320MPa), it seems to be designed for fatigue after all.
So, I was wrong in my initial assumption.
Thank you all!
Components are often designed to meet a fatigue life, rather than a simple yield criteria, especially when considering concentrated stresses, so your situation is not uncommon.
