Duplicating Section Arrows
We have a co-worker who insists on duplicating section arrows that point to a common view. In other words, the same section callout is placed in every location from which the view can be extracted. This is supposedly done for clarity, but a simple parts count in the BOM can quickly deduct (visually) to where the section is applicable, when called out (X places) in the view annotation.
For me, this is not acceptable, and I have never seen it in almost 20 years of professional design experience. That being said, I also do not have a copy of the ASME current standard. It is really causing an issue with clarity in my views, and I don't have time (or resources) to re-size the views to accommodate all of this "clarity".
Can anybody please tell me which of us is in the right here? Either of us will abandon our incorrect position when shown the proper way.
Thank you.
Thank you.
Catia Design|Catia Design News|Catia V5 blog
RE: Duplicating Section Arrows
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
Offhand, I would say your colleague is not wrong in showing the cutting plane more than once, but it's not an absolute requirement.
John-Paul Belanger
Geometric Learning Systems
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
As I stated before, the sections (TYP (X) PLACES) differ slightly, but the same hardware is being shown. It's an installation section, rather than an identical parts section. (if you can understand what I am saying) As also mentioned, there is no confusion, as the BOM readily gives up the used quantities, and there can be no confusion. (as they are also reference bubbled elsewhere in other views)
"We have a co-worker who insists on duplicating section arrows that point to a common view."
I never seen this done as I "think" you have described.
The following companies and generally accepted standards do NOT use this practice:
GE Aircraft, GE Energy; GM, Cummins Engine; Proctor and Gamble; SDRC; Cint Milacron; Rolls Royce; Pratt and Whittney; Delphi; Allison Transmission; Zimmer; Federal Mogal; DOD 100; MIL-STD-130;
One section line.... one view....
For exactly the same feature in multiple locations notation under the section view label is commonly done as follows:
"Notation" of note under section view :
Note under section view: e.g. " 7X LOCATIONS MARKED 'Z' "
Note with leader pointing to the featurs: 'Z'
It sounds as if you are saying that a section line / cutting plane goes thru one feature that is used in various places. If I am understanding this correctly, then I would say it is definetly "illegal" to do what the co-worker suggests. If these same features are used in other positions through out the part, then it would require a notation as stated above or a different section letter for every section line shown on the drawing.
Basic drafting; one section cutting plane, one view behind the section cutting line.
In this case (IMO) what is being attempted for "clarity" would more than likely cause "confusion".
I would argue this is a reason for both your and your co-worker's choice of view development to be wrong. Labeling two non-identical things as identical is begging for somebody to be confused.
Job over, no resolve. We went with the 2 identical callouts (secion plane) for the same view.
