Running a line up a Utility pole
Good day, I have a question about utility poles.
When it comes to running a something up a utility pole, am I allowed to run pvc conduit or does it have to be rigid conduit? The pole is in a parking lot.
RE: Running a line up a Utility pole
If at all allowed, I would consider protecting from physical damage meaning using rigid metal conduit for at least bottom 4-6 feet above grade.
Rafiq Bulsara
http://www.srengineersct.com
David Castor
www.cvoes.com
Bill
"Why not the best?"
Jimmy Carter
