Concrete Slab in Fire
I am modeling a concrete slab with shell element.
1. Can I show the temperature distribution in thickness of slab? How?
2. The HEAT FLUX should be given manually or it will be calculated by ABAQUS? If I must define manually, how can I calculated? Is it vaty with temperature?
