Coating more than 130 degree celsius
Gents,
Anybody can advice what is the suitable coating for vessel which operate more than 130 degree celsius, medium is lube oil and have a pitting problem in it. We suspected the lube oil is not clean/ contaminated.Thanks
RE: Coating more than 130 degree celsius
Have you looked at some sort of anodizing?
TTFN
Chinese prisoner wins Nobel Peace Prize
http://www.hitempcoatings.com/
I'm sure there are others
TTFN
TQVM for the infor, really appreciate it.
The anodize process is not compatible with steel. However, if you're looking for something simple to apply, yourself, there are a number of epoxies and modified epoxy-phenolic coatings available. They will provide you the thermal stability you need. For more information, see this link:
<a href="http://
Best wishes.
William Gunnar
http://www.IndustrialCoatingsWorld.com
I would contact the Shell Technical Group to see if they have some type purification process for contaminated oil. Oxidation seems to be the likely culprit due to the acid formation and resultant pitting.
http:/
Thanks, I will look into it.
