Heat Exchangers and Pumps
Hello Folks, I am designing a chill water system where my cooling load capacity is over 500 tons. I am installing 4 heat exchangers (plate frame) my process loop will have a flow of over 300 gpm at a pressure of 75 psig (at the discharge of the heat exchangers). I have asked several experienced engineers in the fluid flow field and there are mix opinions on where to place the main circulation pumps. Should I place them on the supply side or the return side of the heat exchangers? Can you elaborate on your answers? Thanks in advance for your tips.
RE: Heat Exchangers and Pumps
