"k" dimensions for design v. detailing and 3D CAD
We use Solidworks--just started--and are running into the issue where we want to build our models accurately accounting for strength and weight (ie design dimensions in the weldment tool) but then when a coped beam or web doubler is put in to the "designed" W's and we start manufacturing our inserts are coming in too big due to the "detailing" dimensions that the beams are coming in at.
I was wondering how users are handling the sometimes enormous difference between a W section's "k" dimension for design vs. detailing?
Tony Greising-Murschel
Windows 7 x64
Core i7 870 - 8GB - RAID0 SSD
Nvidia Quadro FX 580
SolidWorks 2011 SP1.0
RE: "k" dimensions for design v. detailing and 3D CAD
As I said all steel dimensions and properties have mill tolerances. I might be unrealistic to expect "exact" weight and strength in your model. Generally both lean in the conservative direction, which is inverse to each other.
http://www.FerrellEngineering.com
