Sequence relays
Sequence relays
Can anyone describe in short or tell me on which website they describe how a electronic sequence relay works? Which principles does this relays use to "see" the sequence is wrong?
Thank you
Christie
Thank you
Christie
RE: Sequence relays
Digital relays detect negative sequence current by measuring all three phase currents and computing the sequence currents using standard sequence current equations. If all three phase currents magnitudes and phase angles are known, all sequence currents can be computed and vice versa.
Zero sequence currents can be computed this way, but are often detected using residual current detection or flux summation methods.
