Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...your web site's great! I've been using this system for almost a year now and find it really, really helpful. The people have been helpful in answering just about any question you post in the forums..."
Geography
vtmike (Mechanical)
9 Dec 10 14:47
I am just starting to use macros in microsoft excel 2007. Does anyone have tips on how I can change the marker color in a XY scatter plot?
4    20    P
5    21    F
6    22    P
7    23    P
8    24    F
9    26    F
For example if the cell in column 3 above has "P", use a green marker & if the cell in column 3 has "F", use a red marker in the plot?
MintJulep (Mechanical)
9 Dec 10 14:49
As far as I know all the markers for any given series of data must be the same.
If you want different markers for different points you need to chart them as different series.
IRstuff (Aerospace)
9 Dec 10 15:05
Actually, it can be done.  There is a "Format Data Point" function, and the macro recorder captured this:
CODE
Sub Macro1()
' Macro1 Macro
' Macro recorded 12/9/2010 by Eden Mei
    ActiveChart.SeriesCollection(1).Select
    ActiveChart.SeriesCollection(1).Points(8).Select
    With Selection.Border
        .Weight = xlThin
        .LineStyle = xlAutomatic
    End With
    With Selection
        .MarkerBackgroundColorIndex = xlNone
        .MarkerForegroundColorIndex = 41
        .MarkerStyle = xlSquare
        .MarkerSize = 3
        .Shadow = False
    End With
End Sub
so, the above selected the 8th point and only changed that one point's color to a shade of blue
TTFN
Chinese prisoner wins Nobel Peace Prize
vtmike (Mechanical)
9 Dec 10 16:38
Well but how do I incorporate an If statement for marker color? Take following code for example for returning the text "PASS", "FAIL" or "NA" based on entries in column 3:
Sub Example4()
    For x = 2 To 7
       If Cells(x, 3).Value = "P" Then
       Cells(x, 4) = "PASS"
       Else
       If Cells(x, 3).Value = "F" Then
       Cells(x, 4) = "FAIL"
       Else
       If Cells(x, 3).Value = "" Then
       Cells(x, 4) = "NA"
       End If
       End If
       End If
       Next x
    End Sub
How do I apply this concept to a XY plot to change color of marker based on the text input in column 3?
IRstuff (Aerospace)
9 Dec 10 17:51
Well, wouldn't you try to call the macro with the point number and a color index?
TTFN
zelgar (Civil/Environmental)
13 Dec 10 12:05
Couldn't you just use Conditional Formatting in the cells to highlight them?
Close Box
Join Eng-Tips® Today!
Join Us             Close
