SAE parallel tooth splines
Does anyone know or can share documentation that references the SAE standard dimensions for parallel splines, specifically the shaft dimensions.  I was able to find the dimensions for the coupling (female) splines in the machinery handbook, however not the shaft splines.  I am specifically looking at a 2-1/4", 6B spline.
thanks.
