310 to G-30 Hastelloy
Wondering if anyone here has had any experience with welding 310 material to G-30 hastelloy material. If so, what SMAW filler metal did you use?
Robert
Robert
RE: 310 to G-30 Hastelloy
My question back to you is what is the intended service of this dissimilar metal weld joint? Corrosion at elevated temperature?
My thoughts are using SMAW process with 3/32" dia electrodes (field install) and Hastelloy X filler metal.
Do you concur?
Robert
For shielded-metal-arc welding,
G-30 alloy covered electrodes
( E N i C r M o -11; UNS W86030)
are suggested.
Ref
http://www.haynesintl.com/pdf/h2028.pdf
