Frame generator and helical curves
I'm trying to model a handrail for a spiral staircase using frame generator. My 3D sketch is made up of several helical curves but I cannot pick these curves once I go to the generator. Can anyone help? I could use the sweep command but the interfaces between the sections would not be right (not perfect mitres).
Cheers,
LewisL
Cheers,
LewisL
RE: Frame generator and helical curves
Cheers.
Years ago. I'm on 2011 now.
You might check your Service Packs for 2009.
http://teknigroup.com/
(nothing to do with your problem statement, but I think I would at least make sure I was on the latest SP)
Cheers
