spiral (helix) metric reinforcement
I tried searching for his but did not find anything. I am performing a conversion of a design from metric to english/imperial and I cannot find anything to explicitly tell me the bar size of spiral/helical reinforcement in a cylindrical footing. The callout is as follows:
4-N16 vertical
R6 helix at 300 pitch
So there are four vertical 16mm (#5) bars and spiral reinforcement at 300mm (1ft) pitch. I suspect that the "N" on N16 refers to the type of steel. I am cannot determine the bar size of the helix however. My assumption is that it is 6mm diameter bar (in which case I would obviously use #3 bar in the US since that is the ACI minimum), but I can't confirm this. I do not think that the "R" could stand for "radius" because a 6mm radius bar converts roughly to a #4 bar which seems quite high for #5 longitudinal. It would also be a tight bend for #4 bars because the overall diameter of the pile is 1'-6".
If anyone can enlighten me on any of these matters I would be VERY appreciative.
Thanks.
4-N16 vertical
Thanks.
RE: spiral (helix) metric reinforcement
If so then the N is Normal ductility 500MPa reinforcing bar (diameter may be slightly less than number given) and the R is a mild steel round member 6mm diameter and could be only 250MPa.
Since it seems you are familiar with Australian design practices, I hope you can clear up a couple other things. The anchor bolts for this structure are M12 Gr.4.6/S H.D. bolts. In some cases this can refer to bent anchor bolts, in others it can refer to threaded rod, and in others it can refer to cap screws. I know what M12 gr.4.6/S means, but what does H.D. bolts refer to? I am not sure if it refers to the actual bolt (such as being a Heavy Hex bolt) or if it is how the part is labelled for purposes of the drawing itself.
Also, what is a "Cog 100 Bolt"?
The cog 100 bolt refers to the hook which is 100mm long horizontally.
Cog 100 means what csd suggested. I would have just said "100 COG" or even dimensioned the cog on the section.
Cog is an odd word on a drawing in the states so I am going to change that to '4 in. hook' instead of 'Cog 100 Bolt'
While we're at it what does the abbreviation c/crs mean? It refers to a square bolt layout and I'm changing it to "o.c." but I'm still curious about the expansion of c/crs.
1. c/c; meaning centre to centre
2. crs; abbreviation of centres
Does anyone know what grade of steel CHS sections typically use? I assume it's similar to HSS (42ksi yield, 58 ksi tensile) but there are some CHS sections here that are smaller than anything available in HSS so I was going to use Pipe but Pipe is different than HSS (yield 35 ksi, tensile 60 ksi) so I want to make sure the pipe will work.
Thanks for the available sections brochure, this is what I've been looking for!
Using hot rolled should be conservative, for identical grades.
I'm guessing it could be true for the US also.
Using Hot Finished instead of Cold Formed isn't a problem, the reverse is (assuming identical grades).
ht
Hope this helps.
