Manually drawing survey lines with R14 & Lddt r1
A surveyor does deed checks and wants the drawing done as described in the deed ie N34d23'45"w distance 342' etc.
How to set up the drawing to match the N coord and where o starts n, e, and the rotation cw or ccw.
Tech1
Tech1
RE: Manually drawing survey lines with R14 & Lddt r1
342@N34d23'45"w
Set your units to 'surveyor' so when you list line information it will report in surveyor units. For checking coordinates, start drawing the parcel boundary at the given cordinates (N/E or x/y).
HTH,
Carl
I think you should pick the start location and type the
coordinates as follow:
@342<N34d23'45"W
There is no need to set the angular units to 'surveyor'.
Farzad
