Adding Components to Assembly
Is it possible to add components to an assembly by dragging them in from the assembly navigator?
RE: Adding Components to Assembly
This can be done from the Reuse Library tab.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
You can also drag them into your assembly from your "History" tab - and you can drag componenets around in your assembly navigator into sub-assemblies (if an individual component needed to be brought into a sub-assembly)
When working in Native mode you can also drag and drop from a windows folder into an existing file.
John Joyce
N.C. Programming Supervisor
Barnes Aerospace, Windsor CT
NX6.0.5.3
